00-About the S5130-HI Configuration Guides
HomeSupportSwitchesH3C S5130 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5130-HI Configuration Guides-R1118P02[R1122]-6W10200-About the S5130-HI Configuration Guides
Download Book
Table of Contents
Related Documents
About the H3C S5130-HI configuration guides
The H3C S5130-HI configuration guides describe the software features for the H3C S5130-HI Switch Series, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios.
Configuration guide
Content
Fundamentals Configuration Guide
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes:
·     CLI
·     Login management (login methods such as Telnet, and user interface configuration and access control)
·     RBAC
·     FTP and TFTP
·     File system management
·     Configuration file management
·     Software upgrade
·     ISSU
·     Device management
·     Tcl
·     Python
·     Automatic configuration
IRF Configuration Guide
Describes the Intelligent Resilient Framework (IRF) technology that is proprietary to H3C. The technology provides data center class availability and scalability by creating a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers.
Layer 2—LAN Switching Configuration Guide
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN and so on. This guide includes:
·     Ethernet interface
·     Loopback, null, and inloopback interfaces
·     Bulk interface configuration
·     MAC address table and MAC Information
·     Ethernet link aggregation
·     Port isolation
·     Spanning tree
·     Loop detection
·     VLAN (including VLAN, super VLAN, private VLAN and voice VLAN)
·     MVRP
·     QinQ
·     VLAN mapping
·     LLDP
·     Service loopback group
Layer 3—IP Services Configuration Guide
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, IPv6 basics, DHCP, DNS, UDP helper, and DHCPv6. This guide includes:
·     ARP (ARP, gratuitous ARP, proxy ARP, and ARP snooping)
·     IP addressing
·     DHCP (DHCP overview, DHCP server, DHCP relay agent, DHCP client, DHCP snooping, and BOOTP client)
·     DNS (DNS and DDNS)
·     IP forwarding basics (Basic IP forwarding on the device and load sharing)
·     Fast forwarding
·     IRDP
·     IP performance optimization
·     UDP helper
·     Basic IPv6 settings
·     DHCPv6 (DHCPv6 overview, DHCPv6 server, DHCPv6 relay agent, and DHCPv6 snooping)
·     IPv6 fast forwarding
Layer 3—IP Routing Configuration Guide
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering. This guide includes:
·     Basic IP routing
·     Static routing
·     RIP
·     OSPF
·     IS-IS
·     BGP
·     Policy-based routing
·     IPv6 static routing
·     RIPng
·     OSPFv3
·     IPv6 IS-IS
·     IPv6 policy-based routing
·     Routing policy
IP Multicast Configuration Guide
Covers Layer 3 IPv4 multicast protocols (IGMP, PIM, and MSDP), Layer 3 IPv6 multicast protocols (MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This guide includes:
·     Multicast overview
·     IGMP snooping
·     PIM snooping
·     Multicast VLAN
·     Multicast routing and forwarding
·     IGMP
·     PIM
·     MSDP
·     MLD snooping
·     IPv6 PIM snooping
·     IPv6 multicast VLAN
·     IPv6 multicast routing and forwarding
·     MLD
·     IPv6 PIM
ACL and QoS Configuration Guide
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes:
·     ACL
·     QoS, including the following features:
?     QoS overview
?     QoS policy
?     Priority mapping
?     Traffic policing, GTS, and rate limit
?     Queue-based accounting
?     Congestion management
?     Per-port queue-based accounting
?     Congestion avoidance
?     Traffic filtering
?     Priority marking
?     Nesting
?     Traffic redirecting
?     Aggregate CAR
?     Class-based accounting
?     Appendixes
·     Data buffer
·     Time range
·     QCN
Security Configuration Guide
Covers security features. The major security features available on the switch include: identity authentication, secure management, and attack protection. This guide includes:
·     AAA
·     802.1X
·     MAC authentication
·     Portal authentication
·     Port security
·     Password control
·     Public key management
·     PKI
·     IPsec and IKE
·     SSH
·     SSL
·     IP source guard
·     ARP attack protection
·     ND attack defense
·     MFF
·     uRPF
·     Crypto engine
·     FIPS
·     User profile
·     Attack detection and prevention
·     MACsec
High Availability Configuration Guide
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes:
·     Ethernet OAM
·     CFD
·     DLDP
·     RRPP
·     Smart Link
·     Monitor Link
·     VRRP
·     BFD
·     Track
·     Process placement
Network Management and Monitoring Configuration Guide
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes:
·     System maintenance and debugging (ping, tracert, and system debugging)
·     NTP (NTP and SNTP)
·     Information center
·     SNMP
·     RMON
·     NQA
·     Mirroring (Port mirroring and Flow mirroring)
·     sFlow
·     Process monitoring and maintenance
·     EAA
·     CWMP
·     PoE
·     Packet capture
·     NETCONF
OpenFlow Configuration Guide
Describes the application scenarios, fundamentals, and configuration of OpenFlow.
Acronyms
Lists the significant acronyms in the configuration guides.
